Il y a comme un hic sur cette "Daytona"
Poster un nouveau sujet   Répondre au sujet    L AMERIQUE A SANCOINS Index du Forum -> Passions autos,motos, tracteurs, moteurs -> DODGE CHARGER A VENDRE
MessagePosté le: Mar 9 Mar - 13:13 (2010)    Sujet du message: Il y a comme un hic sur cette "Daytona" Répondre en citant
http://cgi.ebay.com/ebaymotors/Dodge-Charger-Daytona-1969-68-Charger-Dayton…
Quiquivapa sur cette annonce?
MessagePosté le: Mar 9 Mar - 13:13 (2010)    Sujet du message: Publicité
MessagePosté le: Mar 9 Mar - 13:21 (2010)    Sujet du message: Il y a comme un hic sur cette "Daytona" Répondre en citant
J'en profite pour copier l'annonce car elle se finit demain.
PLEASE READ BEFORE ANY BIDS
This auction is for a 1969 Dodge Charger Nascar Daytona Project The car has the parts to be finished as copy of the Bobby Isaac’s #71 Charger Daytona as ran at the Bonneville Salt flats in 1971
This Project includes:
• Vintage Nascar Intake manifold with 1050 Holley Dominator
• Vintage 10-quart Nascar oil pan with custom oil pickup and windage and New high-volume & high-pressure oil pump
• Vintage Nascar Engine mounts
•1965 NOS shifter
Rearend:
Rebuild to full floater B-Body Specifications:• 1968 B-Body.• New Full floating bearings• New disc brakes
• 2.76 to 1 third member
• Auburn Posi.
• 5 on 5" Nascar bolt circle.
Chassis:
1968 Charger (as many race Daytonas) Specifications:• Vintage NOS 5 on 5", 9 ½"X 15 Nascar steel wheels with new Mickey Thomson tires.• Mittler Brother 5 on 5" disc brake assembly• Vintage NOS Cotton Owens \ Buddy Baker Stainless Nascar Headers.
• Vintage Petty front upper and lower control arms
• Vintage Nascar correct 1961 A-Body steering box
• New Nascar correct firewall.
• New Nascar correct roll cage (started).
• Vintage 1969 Dodge Charger Daytona Rear Wing.
• New Nascar correct torsion bars and struttrods and steering gear.
• New Daytona Charger Steel Nose (Nascar Styled )
• Two 1970 Charger hoods
• New close out Panel and Dutchman’s panel for shortened Daytona trunk.
• New Daytona Charger Trunk Brackets
• New custom Bobby Isaac 71 car Bonneville rear window trim.
• A-body hood hinges
• New inter fender wells
• New 30 gallon fuel cell
• Dodge Trunk steering wheel and column
And allot of other parts that I have forgotten about!
There is No Engine or Transmission
The Car is located in Medford Oregon 30 miles North of the California border on Interstate 5
The Car has a Clean Oregon title and pink slip.
This Car is a project, Please I want you to call with any Questions, I do not want unhappy buyers.
Call and lets make deal!
My cell is (541) 821-3691 OK to call anytime, 24 hours a day!
MessagePosté le: Mar 9 Mar - 13:25 (2010)    Sujet du message: Il y a comme un hic sur cette "Daytona" Répondre en citant
Si j'ai bien compris il te vende la voiture en construction sans rien dedant ni mécanique ni pont ni interieur
la photo fini n'a rien a voire c'est le projet de depart
MessagePosté le: Mar 9 Mar - 13:27 (2010)    Sujet du message: Il y a comme un hic sur cette "Daytona" Répondre en citant
Oui, et tu as vu le bricolage?
Les tubes soudés à l'arrache devant, le capot posé et soudé avec des bouts d'acier.
Je veux pas dire, mais le nez ne doit pas être super bien scellé... un petit peu de portance avec la vitesse et le nez est collé au sol.
En plus le haillon arrière n'est même pas celui de la daytona, c'est le même arrière que sur la tienne.
Si, il y a juste le réservoir qui est pas trop mal.
MessagePosté le: Mar 9 Mar - 13:34 (2010)    Sujet du message: Il y a comme un hic sur cette "Daytona" Répondre en citant
 oui c'est exacte  c'est tout merdique CHUT
MessagePosté le: Aujourd’hui à 06:16 (2018)    Sujet du message: Il y a comme un hic sur cette "Daytona"
Poster un nouveau sujet   Répondre au sujet    L AMERIQUE A SANCOINS Index du Forum -> Passions autos,motos, tracteurs, moteurs -> DODGE CHARGER A VENDRE Toutes les heures sont au format GMT + 1 Heure
