VINTAGE CAMPERS
MessagePosté le: Jeu 12 Mar - 14:46 (2009)    Sujet du message: VINTAGE CAMPERS Répondre en citant
une societé specialisé depuis des lustres dans les vieilles caravannes aluminuium
Welcome to VintageCampers.com
 Ont va commencé par une identique a la mienne
1965 Airstream 22' Safari
Serial # J0225286Price $7000.00Title Yes
EXTERIOR
This 1965 vintage Airstream is in very good shape. Has a very straight and original exterior. Patches have been installed where the furnace and water heater has been removed. The clear coat is coming off and once removed will polish up to a mirror like shine. This is a small/medium trailer which can be easily towed with most SUV's.
Bumper, Frame & A-frame: All appears to be solid and in good shape with only minor surface rust in areas.
Compartment Door/Keys: All original in good shape. Have keys.
Dents, Scratches, Damage: Has a very nice exterior skin. Bottom wraps on the front corners has a couple very small dents. Overall in very good shape.
Entry Door / Keys: Original door in very good shape. Has original aluminum hinge and door lock. Needs new seal and have key.
Entry Step: Original in good shape with surface rust in areas.
Front Hoist: Original in working order.
Hitch Coupler: Original in working order.
Roof: Has original aluminum roof vent in the center. The rear vent has been covered with Lexan to let light in and front vent has an aluminum cover screwed down on it. Roof is in good shape with no evidence of damage. Has 3 small patches between the back 2 vents.
Screen Door: Has original aluminum frame screen door in good shape.
Tail, License & Marker Lights: Has original Signal-Stat tail lights in good shape. Lenses are new. Has original License light with plate bracket. Has original Grotelite marker lights. Lenses are in fair shape. All lights are working in rear.
Underbelly: Has original aluminum enclosed underbelly. Has a 6"x10" patch up front on curbside and has several patches in the rear of trailer around holding tank and sewer drain outlet.
Window Glass/Seals: Has original aluminum frame windows in good shape. All windows have glass, no plexiglass. There is no broken or cracked glass. Plastic strips that hold glass in place have some chips out of them. All windows have original seals.
INTERIOR
This is a very original and intact interior. Has beautiful mahogany woodwork in good shape.
Cabinet - Closet Doors: Original in good shape. Trailer does have all the original plastic drawer trays except for the one at the outside compartment is missing. All trays are in good shape.
Catches: All original.
Countertops: Original white with light brown swirls and brown flecks in good shape.
Floor: Floor is solid in walking areas. Has a soft spot under the toilet approx. 22"x36".
Floor Covering: Original tile with carpet runner down the center and by door.
Table: Yes, original white with light brown swirls and brown flecks in good shape.
Unit Sleeps: 4
Walls: Original aluminum walls painted white. There is a patch on the ceiling between the roof vents. Bathroom walls are cream color fiberglass.
RUNNING GEAR
All appears to be in good shape. Wheel bearings have been inspected and re-packed.
Axle/Springs: Has rubber torsion axle, which appears to be in good shape with only minor surface rust.
Dry Weight: Approx. 3420#.
Hitch Ball Height: Approx 18.
Hitch Ball Size: 2
Hitch Weight: Approx 375#.
Hub Caps: Yes
Spare Tire: Yes, has good tread, but has weather checking.
Tire Condition: Brand new 7.00 - 15LT 10 ply tires on original 6 lug on 5 1/2" center split rims.
FURNISHINGS
Couch/Gaucho: Original Gaucho in good shape.
Curtains: Yes
Dinette Cushions: Original in good shape.
ELECTRICAL
Has original General Electric 2 circuit breaker box. Has a converter to run 12 volt lights from 110 volt power source.
110 Volt Lights: No
12 Volt Int. Lights: Yes, original in working order.
Brakes: Yes, electric brakes in working order.
Breakaway Switch: No
Converter: Yes, in working order.
Int. Fan (s): Yes above stove.
Plug for Ext. Lights: 7 way Pollak brand. This is same plug current trailers use.
Porch Light: Yes, in working order.
RV Battery: Yes
LP SYSTEM
Has original copper lines and pigtails. Entire LP system including appliances should be checked by a licensed professional before use.
Auto Changeover: No
Furnace: No, it has been removed.
Gas Bottle (s): Has 2-30# bottles with new OPD valves.
Gas Light (s): Yes
Gas Regulator: Yes
Range/Oven: Original Magic Chef brand gas with oven and 4 burner stove. Burner and pilot lights.
Refrigerator: Original Dometic brand gas and 110 volt. Cools on electric, but thermostat is bad on gas. Part is available for $99.00.
Water Heater: No, it has been removed.
PLUMBING
Has original copper lines. Found 1 cracked line and has disconnected lines in the back.
Air Pump: No
Fresh Water Tank: Yes
Kitchen Sink: Yes, 2 bowl porcelain white in good shape.
Lavatory: Yes, single bowl fiberglass. Has a couple small surface stress cracks by the faucet.
Sewer Holding Tank: Yes
Shower: Yes, has a 2"crack in fiberglass approx. 6" up from bottom.
Toilet: Yes, original Thetford brand.
Tub: Tub/shower combo.
Waste Holding Tank: No
Water Intake Valve (City): No
Water Pump: No
SPECIAL
This is a very nice Airstream. Has a straight and original exterior. Has a beautiful mahogany woodwork on the inside. These small to medium vintage Airstreams are getting harder to find and the prices continue to rise. With a little sweat equity this trailer would make a good investment that will also give you years of fun & pleasure. Whether taking short camping trips or long vacations this trailer is easily pulled by most SUV's.
OTHER
We can do minor repairs or full restoration to this trailer or other vintage campers if you so desire. If you have not done so yet, you might visit our Restoration page: http://www.vintagecampers.com/restoration.html
Air Conditioning: No
Awning: No
Stabilizer Jacks: Has 4 tripod style stabilizer jacks.
TV Antenna: No
MISC
If this vintage trailer does not suit your needs, please check out all the other vintage campers we have at www.VintageCampers.com.
Equalizer Bars: Has dual cam sway control snap up brackets on A-frame.
Owner's Manual: Yes
Owner's Paperwork: Yes
[td colspan="1" rowspan="1" valign="top"]
Click on photos for larger images.
<- <- Return
[/td]
 VOUS EN VOULER PLUS C EST LA      http://vintagecampers.com/     BONNE VISITE CLIN
MessagePosté le: Jeu 12 Mar - 14:46 (2009)    Sujet du message: Publicité
