Reprogrammation télécommande Cadillac Seville
MessagePosté le: Ven 17 Mai - 10:45 (2013)    Sujet du message: Reprogrammation télécommande Cadillac Seville Répondre en citant
Salut les poulettes;
Voici le mode opératoire pour reprogrammer la télécommande des Seville modèles 1992 à 1995 :
1. Switch ignition to the ON position (don’t crank engine).
2. Locate the Programming Connector (See item 2 in Figure 4) at the back end of the trunk base (not the trunk
lid) above the rear bumper. You may have to pull back the trim to access the connector. It is a plastic connector with
one wire leading up to it that is NOT plugged into anything.
3. The connector should have one terminal. Ground this terminal to a suitable location (bolt, antenna, etc.) and
keep it grounded until completion of the programming sequence. Within 2 seconds of grounding the programming
connector, the door locks will automatically cycle (lock then unlock) to indicate entry into programming mode.
4. Press the UNLOCK button on the first transmitter TWO TIMES (pause one second between presses). In
response, the door locks will cycle once within 2 seconds. (NOTE: If only one transmitter will be used, press the
UNLOCK button TWO TIMES again on the same transmitter and the door locks will cycle once more.)
5. If a second transmitter is to be programmed (including your old one), press the UNLOCK button on the second
transmitter TWO TIMES, pausing one second between presses. In response, the door locks will cycle once within 2
seconds.
6. Remove the jumper wire from the Keyless Programming Connector and switch ignition OFF.
SOURCE : http://remoteandkeyprogramming.com/Programming/185.html
Bonne journée
MessagePosté le: Ven 17 Mai - 10:45 (2013)    Sujet du message: Publicité
MessagePosté le: Jeu 12 Nov - 17:33 (2015)    Sujet du message: Reprogrammation télécommande Cadillac Seville Répondre en citant
Mode opératoire Voici le verser reprogrammeur Modèles La Télécommande des Séville 1992, un 1995
1. Coupez le contact sur la position ON (ne pas lancer le moteur).
2. Repérez le connecteur de programmation (voir l'article 2 de la figure 4) à l'extrémité arrière de la base du tronc (pas de coffre
couvercle) au-dessus du pare-chocs arrière. Vous pourriez avoir à retirer la garniture pour accéder au connecteur. Il est un connecteur de matière plastique avec
un fil menant à ce que est pas branché sur quoi que ce soit.
3. Le connecteur devrait avoir un terminal. Rez de ce terminal à un endroit approprié (boulon, antenne, etc.) et
maintenir la terre jusqu'à l'achèvement de la séquence de programmation. Dans les 2 secondes de mise à la terre de la programmation
connecteur, les serrures de porte automatiquement le cycle (cadenas puis déverrouiller) pour indiquer l'entrée en mode de programmation.
4. Appuyez sur le bouton de déverrouillage de la première émission deux fois (pause d'une seconde entre les presses). Dans
réponse, les serrures de porte sera une fois le cycle dans les 2 secondes. (NOTE: Si un seul émetteur sera utilisé, appuyez sur la
Touche de déverrouillage DEUX FOIS nouveau sur le même émetteur et les serrures de porte fera un cycle une fois de plus.)
5. Si un deuxième émetteur doit être programmé (y compris votre ancienne), appuyez sur le bouton UNLOCK de la deuxième
émetteur à deux reprises, une pause d'une seconde entre les presses. En réponse, les serrures de portes fera un cycle une fois dans 2
secondes.
6. Retirez le cavalier du connecteur de programmation sans clé et mettez le contact.
MessagePosté le: Aujourd’hui à 18:39 (2018)    Sujet du message: Reprogrammation télécommande Cadillac Seville
